Android 16.2.0 for Teracube 2s (SN:2025)
NOTE 1 : These builds ONLY WORK for the Teracube 2s (SN: 2025) Sapphire, and not Teracube 2e batch (SN:2021/SN:2020).
NOTE 2: It is expected for the device to stay longer on Teracube logo for the first time after installing the upgrade & The device may respond slow for some time after upgrade, apps are optimising in background. We recommend waiting 15min on idle post upgrade before using it for an optimal experience.
We are thrilled to share our (16.2.0+f78e446) Android 16 QPR2 for Teracube 2s 2025
:tada: What’s New?
  • :iphone: Update to Android 16 QPR2 with February 2026 security patches
  • :signal_strength: Fixed WPA3 Wi-Fi connectivity issues
  • :rocket: Slight improvements to app retention in memory
  • :art: Material 3 expressive design updates
  • :gear: New Quick Settings UI
  • :bar_chart: New status bar icons
  • :house: New Launcher updates
  • :sparkles: Enabled blur effects
:inbox_tray:Steps to Upgrade:
  1. Download the upgrade zip
    file directly on the phone (or transfer the zip to the phone).
  2. Goto Settings > System > Updater (or Teracube Updater)
  3. Click top-right 3 dots > Local update or Click on the top-right File icon
    Note 3 : Before you update, make sure you have at least 6GB of free storage and your battery is at least 50% charged. This will help ensure a smooth update process.
    Note: If the Updater closes or crashes, then try again.
  6. Upgrade process will take a while.
  7. Reboot the phone after the updater says “Update installed”.
  8. First boot after upgrade can take several minutes.
Do note, after the update, you’ll need to re-enroll your fingerprint and some users have reported that they lose their launcher - icon and widget arrangement. We’d suggest you take a screenshot of your homescreen before performing the update!
