Android 16.3.1 for Teracube 2e 1st Batch Zirconia (SN: 2020)
Generally, you want to stay between 20 and 80-90% charge on Lithium cells to prevent dendrite formation, which rapidly degrades the cell.
That being said, most cells are rated at about 1,000 cycles or so. A cycle is any time the chemistry is forced to reverse and store a charge vs discharge. So, be it a full charge of 1.5ish hours or ten seconds on a charger before you pull it off, that’s a cycle.
Light users consume 1-2 cycles a day, or 3+ for heavier users, so 1-3 year life is not abnormal.
Like Maymne recommended, Accubattery is incredibly good for figuring out cell health by watching your charge/discharge cycles and patterns, reported charge/discharge rate, estimated vs actual runtimes, etc. A few days of using that should help you suss out if the cell has degraded or not.
Common mistake in understanding battery specs. The manufacturer refers to “full cycles” which means going from zero to 100%. So every other charge/discharge cycle has to be converted to this metric (only 3 year battery life would be hilarious). There are indeed some other factors benefitting battery life or vice-versa but we’re talking negative effects after 5-10 years.
Has anyone tried updating from Android 13 (specifically 13.1.1) all the way to Android 16 (looks like 16.2.1) in a single step? Or should I go in order 13 > 14 > 15 > 16?
Its doable but no assurance of data moving safely
It worked! The upgrade from 13 > 16 went well. I think the only problem right now is the Gmail app is not updating for some reason. I rebooted a few times and tried to do the update a few times, but it still fails. The other apps didn’t have any issues updating though.
Can you disable/re-enable it to reset it and force an udpate from the Store?
I tried to disable/re-enable, also tried rebooting in between. But the app updates are still not working. Now it shows other Google apps (Gmail, Google Calendar, Google Chat, Google Messages, and Google’s Find Hub). They’re all stuck, and can’t complete their updates. I also tried switching to another Google account, but that didn’t help either.
I haven’t seen any new updates for my non-Google apps in the past week. I’m not sure if this is related. Normally, I get at least a few updates every day from the Play store.
We will deliver an OTA update to address this issue. Thanks for your patience!
I logged in just to see if it was me or the phone. Never had a problem before so assuming it’s the updates themselves from the play store. Mine also includes Contacts.
New update available for Zirconia:
:tada: What’s New?
  • :warning: First boot after OTA may take a few extra minutes to settle.
  • :lock: June 2026 security patches
  • :rocket: Improved app launch speed
  • :brain: Better multitasking & less app killing
  • :battery: Performance & battery improvements
  • :sparkles: Faster animations
  • :bug: Fixed apps not updating
  • :bug: Fixed Play System Updates crash
  • :bug: Fixed wallpaper not applying
  • :bar_chart: OTA update progress now shown in boot animation
  • :gear: Launcher app suggestions disabled by default (can be re-enabled in Launcher Settings)
  • :gear: Disabled haptics in launcher
  • :broom: General stability & cleanup improvements
Check for updates today!
Seemed to install fine last night. Haven’t done too much with it yet, but I really appreciate the percentage during boot animation.
Many thanks for this!! Really appreciate the constant updates for this device!! Still using it. Update went well.
Is there any experience with an update from Android 10 to the 16.3.1?
If it is needed to do a factory reset, or if there is a big possibility that the user data is lost anyways, during the update, i go the extra mile and switch to e/os instead.
Unless you’re doing each step and planning on having a 2-3 day process of constantly updating and restarting over and over, expect that data will likely be lost when skipping two dozen incremental updates. That being said, the current /e/OS for the Teracube is AOSP 15 (unless you’re on the 2s in which case it’s 14) not 16, so it’s a lower base, though it did get its monthly update three weeks ago. Regardless, up to you whether you’d prefer sticking in the Google ecosystem with Android 16 or avoiding it at least temporarily - whether you try to take their official 15 or build your own 16.
/e/OS is now base 16 for zirconia, emerald, and sapphire all :slight_smile:
I updated successfully from v13 > v14 and then to this one, no problems so far!
