Case survey
Just received mine from AMAZON. Nice case, glad for the purchase. Now when is the next update for 11comin?
I received my Teracube case from Amazon and it is spectacular! Well done.
Im also waiting until it can be sold on the site. I don’t use Amazon at all…
Waiting for payday next Friday and ordering 3 of them one for each of our phones.
Anyone have any luck getting a grip of any kind to stick to the new case? I need to buy a new one but in the mean time I tried some pop sockets I have and they will not stick at all.
You could try one that is a full adhesive rectangle. Those will generally stick to anything. Amazon has one that is twenty dollars (the name escapes me), but it slides out so you can use it as a stand or a finger loop. Just search for “adhesive phone stands” and you’ll get some results. I find that the full rectangle adhesive accessories last a really long time (even the Onn stick on wallets from Walmart for 5 bucks are amazingly sticky). The more surface area the stickiness covers the better.
Hi @Cindy_Chudacoff - did you buy the case and if yes, did it work? If you haven’t bought it yet, I’ll suggest you can give it a try. Amazon makes it easy to return if you don’t like it. This will be a good test for everyone else waiting for the same answer :slight_smile:.
Ha! You think anyone beside you and I are waiting for the answer? I am still considering buying it. I bought a couple of inexpensive generic wallet cases that work for me so I haven’t really gotten desperate for a new case yet, but I promise to let you know.
Update : The case is now live in UK and EU. All links available here.
And if you will like to get the case off-Amazon in the US, just send us an email at support@myteracube.com and we can get that going for you (US only).
A post was split to a new topic: Teracube case not orderable in Netherlands
QI Wireless charging works with the new case! Everything fits well and charges perfectly. I have to agree that some other color choices would have been nice, but I like the case a lot for its power and volume button protection.
Answered in another place, but yes it does work with the new case! The nice thing about the black, opaque case is that you cannot see the taped-on receiver, so it gives the back of the phone a nice, clean look, in addition to better power and volume button protection.
Thank you so much! I am going to order one off Amazon then. Would make managing all the stuff I have plugged in so much easier and I have an old wireless charge pad in a drawer for my old BlackBerry Priv I can put to use again (I am big into not throwing useful things away).
New case is much better!
Works great, even over our Nilikin MagicTag Qi pads.
Front lip really protects the screen. Buttons are well-protected as well, and click with authority.
Looks like you need to install the tampered glass protector soon. LOL
After a few weeks of usage, reports of phantom volume changes and reboots to recovery are all but gone, as I had expected.
The extra firmness in the buttons helps a ton for preventing these support issues with my family.
I can’t get shipped to France, neither from the .uk nor .de (I even tried with .com)
What I can do ?
