After update to Android 11 face unlock is missing under security tab - will this be back later?
Yes - we had to remove it. The reason being it was provided as a proprietary component by Mtk. While our new build is as close to base AOSP (open source) as possible. I’ll check with Devs if we can add it as an optional component.
