Google Fi setup
Teracube is “Compatible with Google Fi”.
New Fi users
If you are setting up a new Fi account - a heads up : You will not see Teracube in the supported phones list on fi’s website. Just select any unlocked Android like Huawei Honor 8 or Oneplus 7 (unlocked) and you will be fine.
Activate SIM
Once you have the SIM, pop it in and install Google Fi app. Use the google account associated with your Fi and follow the app through activation.
SIM Activation errors
If you experience error code T080, T209 or some other code, try the following:
  1. Make sure your SIM is seated properly. If you see wireless signal in status bar, then SIM should be fine.
  2. Reboot the phone and try Activation.
  3. Goto Settings > Apps & notifications > Google Fi > Storage. Clear Data and Clear Cache.
  4. Open Fi app and try activation again.
