LTE Data not working on Fizz (Canada) - Solved
After updating to Android 11, it appears that I can’t connect to the internet when using data. It took me a bit to notice since I don’t leave the house every day. I’ve tried restarting with no luck, and regular wifi (via a connection like my home wifi) still works.
Seems like an APN setting issue. What carrier are you using?
I’m using Fizz
Can you check if you have the right APN settings:
Fizz APN settings are:
  • APN: mobile.bm
  • MMSC: http://mms.mobile.bm
  • MMS proxy: mmsproxy.mobile.bm
  • MMS port: 80
  • APN type: default,mms,supl
Were you able to fix the issue? If yes, could you share how - was it just entering the above APN?
A post was split to a new topic: Data on Mint Mobile?
