2e main camera replacement part needed
Since my request to support@myteracube.com seems to have been ignored, I’ll try it here.
The main camera (ID:0) of my Teracube 2e (2020) failed. Due to the symptoms, I’m sure it is a hardware problem. So I’m asking for a new camera module for replacement. What do I need to do to get one? I’m living in Germany.
Thanks in advance,
Manfred
Sorry! I missed this thread somehow.
Can you PM me the email you used for contact and I’ll make sure Support reaches out to you about a replacement camera part?
Thanks, Saijin!
I may have been too impatient. In the meantime, I have successfully contacted customer support and am corresponding with Shanin. He might give you some info on the situation if needed.
Best regards,
Manfred
Glad you are getting help, and I hope things get resolved to your satisfaction!
