Additional charging cord
Where can I order an extra charging cord?
It’s a standard USB Type C and USB Type A that you can buy a lot of places. Here’s one from NewEgg:
https://www.newegg.com/black-tripp-lite-3-ft-usb-3-1/p/N82E16812329524?Description=usb%20C%20usb%20A&cm_re=usb_C_usb_A--12-329-524--Product
And there are many on Amazon as well :slight_smile:. Just make sure one side is USB-C and other is regular USB (USB-A)
Amazon link
If you have a micro-USB cord (or more, if you’re like me and still have a phone using it) hanging around, there are also micro-USB to USB-C adapters too instead of tossing them out. Just make sure it supports OTG (On-The-Go) if you want to transfer files to a computer.
https://www.amazon.com/dp/B01I0ZAJXO/ref=cm_sw_r_cp_apa_i_xXXxEbDB6RS0R
it is bad to use a usb-c to usb-c cord to charge?
USB-C to USB-C cords will be fine (no difference in charging). Reason I suggested USB-A (regular USB port) to USB-C is because our included charger has the USB-A port.
Ok great. I just wanted to double check cause I’ve used a usb-c to usb-c before.
Just curious, do you know if there is any change in charging speed with a fast charger compared to the stock charger? I feel like the stock one does a good job time wise but was curious.
Teracube uses 10W charging (upto 5V,2A) which the stock charger is designed to provide. Any higher power charger (example 15W or 18W) will not charge it faster.
You can use Acubattery (or other similar apps) to view charging current.
ps: Somewhat related. Most smartphones draw the max current (2A for Teracube) upto a certain battery level (approx 80%) and slow down after that to preserve lithium batteries.
hi - were can i buy another charger for my phone??
The post below has a link to USB-A to USB-C cable (you can couple with any USB charger)
