Note: This would be needed if Teracube team is asking for logs for troubleshooting a particular issue.
**Pre-setup for Google Family Link users: ** If your Thrive phone is managed by Google Family Link, then follow these steps 1-5:
P1. On the parent phone, open the Family Link app
. If you don’t have it, then install the Google Family link app on the parent phone
P2. Select your child.
P3. Tap Controls > Devices .
P4. Tap “Teracube 2e”
P5. Scroll down and enable “Developer options”Now Continue the below steps
For all Thrive phones:
- Open Settings on your child’s phone> About phone
- Scroll to bottom and Tap “Build number” 7 times. Enter password if required.
- Developer options will now be available
How to take logs
Once developer options are enabled, do the following to take logs:
- Open Settings > System > Advanced > Developer options
- Tap “Bug report”
- Tap “Generate full report”. This will take 4-6 minutes to create the bug report.
- A notification will be there once the bug report is ready. Tap it to share it via email to support@myteracube.com.
