On the first launch, you’ll notice a clean setup with a beautiful wallpaper from Hampus Olsson, who teamed up with us again to create several beautiful pieces of artwork. Hampus is a multi-disciplinary artist whose design stands for itself and we’re glad to have him onboard. We also added further UI touches that we believe enhance the overall user experience. You can find all of the Paranoid Android wallpapers and many more in the Abstruct app, included in our builds.
Our builds are based on the Code Aurora Forum Android base, which is optimized for Qualcomm platforms and has a higher degree of performance, battery life, and functionality compared to the Android Open Source Project platform. The Paranoid Android team and contributors are focusing on squashing existing bugs, and implementing and improving features, performance, and stability. We are dedicated to providing a user experience with the stability that you can expect from stock ROMs with best-in-class performance and features to help you get the most out of your device.
Welcome to Paranoid Android.
Device-specific issues
WiFi STA+SAP concurrency doesn’t work
WiFi calling doesn’t work, options grayed out since AOSP telephony stack on CAF
Release notes on AOSPA-2e/releases.
Note: Custom kernels are NOT supported unless the kernel says it supports PA and GMS is included!
Firmare required: Stock SW6. It will not work on firmware above SW6.
Optimized CAF to run on MediaTek chipsets without much hacks.
Preferably, use a single SIM card since I don’t have two to test.
Grab the releases at:
- TWRP release for the Teracube 2e: TWRP [Encryption on TWRP is still dead at the moment, do not panic if you don’t see your files in TWRP, they are all safe, and sideloading is preferred]
- Paranoid Android Ruby Beta 1
Instructions to install:
- Download the latest ZIP and my TWRP release.
- Reboot to bootloader.
- Flash the recovery using
fastboot flash recovery recovery.img - Reboot to recovery using
fastboot reboot recovery - Flash the ZIP via recovery, and reboot.
- Wait for a while, the first boot will take quite a lot of time.
Sincere thanks to Jake, Elias and Teracube.
Kernel sources: AOSPA-2e/android_kernel_teracube_2e
ROM sources: AOSPA
Entire device sources: AOSPA-2e.
