Hi,
I have my Teracube 2e set to schedule a power off and back on overnight.
When it restarts, the auto-rotate setting (previously on) is off. 5 days in a row now.
Android 10.
Any ideas?
Thanks,
RC
Hi,
Android 10.
Any ideas?
Thanks,
RC
Hi @ronniecoote - welcome to Teracube forums. Could you check if this happens on a regular reboot as well?
Hi Sharad. More data now, from this week’s auto-restarts:
7 x scheduled restarts this week (phone off at 1am, on at 6am)
2 X auto-rotate disconnected, 5x no problem
Previous week: I noticed 5 days in a row where auto-rotate disconnected.
Manual power off: I tried it twice, and auto-rotate stayed selected (correctly) both times.
Thanks,
RC
Based on what you are noting, it seems the scheduled restarts might be causing the auto-rotate to turn off. I’ll add it as a bug in our list. However - will keep it little lower in the order if you don’t mind.
