Best way to clean the phone
I’ve used Purell wipes on my teracube screen and I realized that it scratched my plastic screen protector. So does anyone know the best way to clean the phone without damaging the device (scratching the glass or screen protector)?
put it in a UV sterilization container? (for the proper amount of time*)
*quick passes are just gimmick or “security theater” rather than effective
I use a micro-fiber cloth with a screen cleaner; try and see if that works better if you have one? If you have a Walmart near you, they usually have a set for about $6-8 that come with a cloth, 4oz cleaner and some wipes, which is what I used.
