"Call can't be placed by T-Mobile" error - can't place phone calls
I tried placing my first phone call today (I hate phone calls, actively avoid making or taking them, and yes, it’s that rare).
This wonderful message greeted me.
I tried airplane mode toggle, switching off WiFi calling, and switching off WiFi completely. No change.
“Call can’t be placed by T-Mobile. Try using a different call redirecting app or contacting the developer for help.”
I don’t know what call redirecting app it’s referring to - but I have T-Mobile Scam Shield and Visual Voicemail installed. Closest thing I can get to contacting a developer is the phone manufacturer now, so here we are :wink:
I’ve just got standard T-Mobile, not an MVNO or anything.
I’m going to try beating my head against this to resolve the immediate need to make a call, but I thought it needed to be mentioned since I can’t find a single occurrence of this error being quoted by anyone in the context of a Teracube so far! Or anyone else with any useful input, for that matter… I seem to be alone in this issue.
Problem solved: there is a literal app called “T-Mobile” which the system was trying to use for calling.
That app had all its permissions denied by default, since I’d never opened it (it was restored when I set up the phone from a backup), and it hadn’t been initialized.
I just went through the T-Mobile app’s permissions (long-press the T-Mobile app, “app info” button, then “permissions”) with a sledgehammer and allowed all its requested permissions, then went through the setup process for the app (simply opened it and made it happy, signed in, etc). Then, no problems making calls! Yay.
None of our TMobile connections require/use this app. Are you using their Digits system to make calls or have you inserted an actual TMobile SIM in the phone? If using the SIM, then you don’t need that app.
Didn’t say I needed it, just said I have it. It was installed from the backup, and honestly, part of the reason I have T-Mobile and not an MVNO is that I like the features offered by T-Mobile in their app (and I like letting T-Mo know what phone I’m using :wink: ).
All I had to do was remember that an app called T-Mobile was actually installed (which I did by finding it in the “default apps” page of Settings), and voila… it had all its permissions denied by default, which caused the issue.
Of course I have a T-Mo SIM, but the entire idea of “needing the app” doesn’t play in here at all - I already had it installed (partly unknowingly - by restoring from a backup), and that was the problem.
Thank you, you’re a lifesaver. I came across this post by accident. I have the same problem and you’re solution Helped me solve my problem. I had T-Mobile techs working on my situation for days and days. Set me a new phone and ran into the same problem about 8hrs later after the new phone updated. At that point I knew it had to be something related to apps but still didn’t solve it. Bless you for sharing The solution with the rest of us.
By the way…all i had to do was choose the O none option…after i tried allowing permissions to T-Mobile and T-Life apps didnt work.
Where did you find the o none option?
I solved problem after update phone selected the T-Mobile App itself as default redirect option even though i never even saw that option to open …Settings - Apps- choose default apps - at this point “redirect caller” shows the apps - T-Mobile, T-Life, or None. I tried T-Life since the other T-Mobile didnt work and T-Life also failed. Selecting the option 0 None was successful
Ty Vincent. My friend had been playing with her phone and knew she changed something but couldn’t remember what it was until I used my phone to look it up and you directed us exactly to the right thing the “zero option”. It worked!. Ty so much!
My husband’s phone call directing app was also set to T-Mobile but mine was set to none. I could make calls. He could not. Spent 1 hour on the phone with T-Mobile and they couldn’t fix it. Googled the error message today and got this teracube site and it fixed the problem in 30 seconds. Thanks for your help.
I spent a hour on the phone with T-Mobile Tech support. They couldn’t figure it out. The guy wanted to me to reset my phone but I said NO. He convinced me to reset my network settings, which I did. That didn’t resolve the problem, now I can’t logon to my Networks Access Points that I don’t own. I wish that I had seached google first! :frowning:
Was having the same issue followed these steps and now I can make all calls on my contacts thank you so much I was beginning to have a panic attack
Had the same issue was panicking but after I calmed down I was able to fix it thank you so much
Is this an Terracube only issue? I was in Germany 3 years ago and used T-mobile on a Samsung and 2 years before with a Blackberry. No issues.
Sorry I got T Mobile mixed up with the Parent company Deutsche Telekom, lovingly known as TeleKoma.
It was the tmobile diagnostic app for me, my phone been doing this forever
