Call Recording
Has anyone managed to get call recording working recently on a Teracube 2e? I am in a jurisdiction where call recording is perfectly legal. I want to use it generally to record calls with companies who also record the call.
I am currently using /e/os and the call recorder in the dialer app is there but it always fails (in adb it shows errors related to finding the audio device). I am happy to switch to a different ROM if someone says they have it working.
Hi, I think the /e/ OS Call Recorder has some issues (maybe), can you attach a adb logcat?
you can take logcat using adb logcat > call.log while reproducing the problem, and then upload and attach the file here.
Also in my opinion you can try LineageOS Builds of Teracube 2e, just make sure to flash correct file, as Teracube 2e has two models, Teracube 2e (SN 2020) which has internal codename 'zirconia, and teracube 2e (SN 2021) codenamed emerald` . They should have call recording working.
Also you can try out GSIs, if you like.
Regards,
Aryan Sinha,
AOSP Developer & Linux Enthusiast
I believe this is the relevant section of the logcat. Have you seen call recording working on the LineageOS builds?
07-08 09:58:31.963   605  3088 I Codec2Client: Creating a Codec2 client to service "software"
07-08 09:58:31.966   605  3088 I Codec2Client: Client to Codec2 service "software" created
07-08 09:58:31.979   499   499 W IMGMemtrackHAL: hal_get_memory: memtrack cache rebuild was required
07-08 09:58:32.038  2555  2555 D Documents: Content updated.
07-08 09:58:32.038  2555  2555 D ContentLock: run when unlock, is locked : false
07-08 09:58:32.039  2555  2555 D Documents: Content updated.
07-08 09:58:32.040  2555  2555 D ContentLock: run when unlock, is locked : false
07-08 09:58:32.061   478   812 D AudioALSAStreamManager: getInputBufferSize(), sampleRate = 8000, format = 0x1, channelCount = 1, bufferSize = 320
07-08 09:58:32.068   518  1949 D PermissionCache: checking android.permission.CAPTURE_AUDIO_OUTPUT for uid=10131 => granted (367 us)
07-08 09:58:32.071   518  1949 W ServiceManager: Permission failure: android.permission.CAPTURE_AUDIO_HOTWORD from uid=10131 pid=6925
07-08 09:58:32.071   518  1949 D PermissionCache: checking android.permission.CAPTURE_AUDIO_HOTWORD for uid=10131 => denied (603 us)
07-08 09:58:32.071   518  1949 E APM::AudioPolicyEngine: getDeviceForInputSource() no default device defined
07-08 09:58:32.071   518  1949 W APM_AudioPolicyManager: getInputForAttr() could not find device for source 4
07-08 09:58:32.071   518  1949 E AudioFlinger: createRecord() getInputForAttr return error -22
07-08 09:58:32.071   605  1523 E IAudioFlinger: createRecord returned error -22
07-08 09:58:32.072   605  1523 E AudioRecord: createRecord_l(0): AudioFlinger could not create record track, status: -22
07-08 09:58:32.073   605  1523 E StagefrightRecorder: audio source is not initialized
07-08 09:58:32.074  6925  6943 E MediaRecorder: start failed: -2147483648
07-08 09:58:32.102   681   759 D AAL     : 07-08 09:58:31.957 BL= 386,ESS= 256, 07-08 09:58:31.992 BL= 385,ESS= 256, 07-08 09:58:32.029 BL= 384,ESS= 256, 07-08 09:58:32.065 BL= 383,ESS= 256, 07-08 09:58:32.102 BL= 382,ESS= 256,
07-08 09:58:32.106  2555  2555 I ProvidersCache: Updating roots due to change at content://com.android.providers.media.documents/root
07-08 09:58:32.119  6925  6943 W CallRecorderService: Could not start recording
07-08 09:58:32.119  6925  6943 W CallRecorderService: java.lang.RuntimeException: start failed.
07-08 09:58:32.119  6925  6943 W CallRecorderService: 	at android.media.MediaRecorder.start(Native Method)
07-08 09:58:32.119  6925  6943 W CallRecorderService: 	at com.android.dialer.callrecord.impl.CallRecorderService.startRecordingInternal(CallRecorderService.java:19)
07-08 09:58:32.119  6925  6943 W CallRecorderService: 	at com.android.dialer.callrecord.impl.CallRecorderService.access$100(CallRecorderService.java:1)
07-08 09:58:32.119  6925  6943 W CallRecorderService: 	at com.android.dialer.callrecord.impl.CallRecorderService$1.startRecording(CallRecorderService.java:1)
07-08 09:58:32.119  6925  6943 W CallRecorderService: 	at com.android.dialer.callrecord.ICallRecorderService$Stub.onTransact(ICallRecorderService.java:22)
07-08 09:58:32.119  6925  6943 W CallRecorderService: 	at android.os.Binder.execTransactInternal(Binder.java:1021)
07-08 09:58:32.119  6925  6943 W CallRecorderService: 	at android.os.Binder.execTransact(Binder.java:994)
07-08 09:58:32.119   605  1523 W StagefrightRecorder: stop while neither recording nor paused
07-08 09:58:32.120   605  1523 W StagefrightRecorder: stop while neither recording nor paused
07-08 09:58:32.121   605  3088 W StagefrightRecorder: stop while neither recording nor paused
This looks like a source side issue, that is maybe due to a missing permissions.
Secondly, I do not own 2e yet, but ideally call recording should work on LineageOS Builds.
Just make sure to flash correct file, as Teracube 2e has two models, Teracube 2e (SN 2020) which has internal codename zirconia, and teracube 2e (SN 2021) codenamed emerald .
Else you might end up with brick.
Regards
