Camera not working on replacement Teracube 2e
About a month ago, I received a replacement Teracube 2e after my previous device was damaged due to water exposure. I paid the required repair fee, but unfortunately, the camera on the new phone does not work. It says another app is using the camare, but it is not right
I’ve tried restarting the device and using alternative camera apps such as Open Camera, but the issue persists. I’ve also attempted to contact Teracube support multiple times via email (support@myteracube.com), but I haven’t received any response.
I originally purchased my first Teracube device in 2023, so it’s been about two years. Since then, I’ve experienced several issues—mostly related to the camera—and have had my phone replaced under warranty at least three times.
I would appreciate any assistance or guidance on how to resolve this issue.
Thank you in advance.
Sorry to hear about the issues you’ve had.
Can you provide a bit more information about the phone?
It is likely an emerald (2021x serial), but what version of Android does it have? Have you upgraded to the latest v14.1.x stable and re-tested?
What camera(s) do not work? Front, back, back wide, all?
Hi Saijin,
Thanks for replying! Sure, I can provide the information.
I’m using an Emerald device and have already upgraded to the latest version (v14.1), but unfortunately, it didn’t resolve the issue. Both cameras are still not working, and I’m starting to get worried because I haven’t received any response from the support team
Thanks for confirming!
I have reminded the team to review your suppory requests, so you should be contacted shortly.
Thank Saijin for your reminder. I hope it work. In the last weeks my mails and tickets have been ignored.
keep waiting for a reply. I sent my old unit as well, and I should have received a refund.
Alright, let me re-follow up with the team again.
I apologize.
Thanks for replying. Hopefully, I’ll hear something from support soon.
No news from support. I have a teracube 2e with a camera that is not working… and they keep ignoring my emails. Fantastic
I apologize, this is not how we want to handle support. I will re-contact them.
I have the same problem. I’m using e/OS 3.14 Emerald (from Jan. 14, 2026). I sent back my Teracube 2E (cracked screen) and received a Teracube 2S. The camera is so bad, it won’t even pick up a QR code. Support has ignored me. I’ve no problems with e/OS and I really appreciate the whole ecosystem. I’m not sure I want the hardware of the Fairphone and don’t want a Pixel, even with e/OS installed. So, I am considering buying something with a Graphene OS. I don’t know. I just want this phone’s camera to work.
Mark
The camera module should behave nearly indistinguishably from the 2e with the same settings.
What are you using for barcode scanning?
If Binary Eye, it should Just Work.
For the in-built /e/OS Camera (OpenCamera fork), I’ve found I need to disable Noise Reduction and set sharpness to max quality in processing settings (and have decent lightning, far less forgiving than Binary Eye).
I’ve tried that and it still doesn’t work. I got this Teracube 2S only because I had to send in my 2E for a screen repair. Can I swap this 2S for a 2E??
I’m not sure if they can guarantee replacement stock of 2e specifically, but I’ll ping and ask.
The label on my phone (underneath the battery) identifies this as Teracube 2E but in the Settings “About” it is called a Teracube 2S. Why would that be?
Not sure, unless a mistake was made during refurbishment or device assembly.
What are the first four of the serial?
Contact support@myteracube.com and reference this thread so they can arrange a 2e replacement for you.
We have not been able to replicate the QR Code scanning difficulties with the 2s internally, unfortunately.
First 4 of the SN is 2021
But Teracube has initiated the replacement process on Monday, March 16.
Thanks
