Can't change Google Calendar nofitication sound (android.process.media keeps stopping) on a TC One
On a fresh, factory reset phone (Android 10.0.2+d087f19.user), whenever I try to change the notification sound in Google Calendar, the settings app continually crashes. If you try to set it again, Android will complain, “android.process.media keeps stopping”.
Steps to reproduce:
  1. Open Google Calendar on a newly reset phone.
  2. Open Settings
  3. Select General
  4. Calendar Notifications
  5. Advanced
  6. Open Sound (default is set to “App provided sound”)
  7. [crash]
Has anyone else experienced this issue? Does anyone know of a workaround?
infamia, I have both a teracube1 and 2e. On the T1 (10.0.1) I reproduced your steps and it crashes. On the 2e_16 I’m able to get to the pull down of any other sounds. Hope this helps.
Have created an internal ticket on this.
