Can't find APN settings
I have just gone back to using my 2E after a few years. Photos and group messages are not coming through in messages. I am trying to find my APN settings to no avail. They are apparently under “mobile network” which is supposedly under “Network & Internet.” The closest I have is “mobile plan” but when I click on that, it says “Public Mobile has no Provisioning website.” I am using Android 13. I have looked everywhere, but can’t find the APN settings on my phone. Can anyone help?
Thanks!
If you type “Access Point Names” into the search bar in Settings and wait a bit, does it show a result?
Thank you. I finally found it. So now my question is do I have to change everything in the APN? Or just a few things? I have found a list but it is from 2020. Would they still be valid? At the moment, photos and group messages are not making it through.
The authoritative source for APN settings is your carrier. Most of them have a Support website with them listed, but their phone team also will have the proper settings if you call in.
Thank you so much!
