Update (Aug 28, 2020):
And the cases are live on Amazon (US and CA). You can find the links here.
Update (Aug 24, 2020):
We have received the shipment of the new cases. Check out the pics here. We should have them up for sale within a week or so.
Update (June 11, 2020):
Work on the new case has started. Manufacturer is in the tooling stage right now.
On a related note : Please install a glass screen protector as mentioned in our security advisory. If you are looking to buy one, here is our recommendation.
Hi Everyone,
Based on feedback from you all - we are working on developing a more protective case for Teracube. Would love to your feedback on some potential designs. There are 6 cases below : 1-5 are samples and No 6 is similar to Spigen armor case on Amazon (the spigen armor photo and link is just for reference - the final case will be designed by us).
Note 1: The final colors will not be the ones shown here. Probably Black or clear.
Note 2: These are samples from other phones. The final designed case will have the right cutouts for fingerprint scanner, charging port, headphone jack, etc.
![Case6-Numbered|205x300]
- Case 1 is the thickest case. It is made of black TPU and has a rugged style yet flexible. It has a good amount of “lip” above the screen.
- Case 2 is quite thin, and slightly softer than case 1, with a subtle leather pattern.
- Case 3 mixes slightly soft plastic (in red) with hard plastic (in silver) and has a slot to hold credit cards. It is heaviest of the lot as well.
- Case 4 is more rubbery than the first three, and is clear. It is more rugged than the included case. The corners protrude and have air pockets to protect the phone during a drop.
- Case 5 is more rubbery than others, and has a velvety feel and appearance. Can be made with a good “lip” to protect screen.
- Case 6 is soft black plastic with a good amount of raised lip to protect the screen. Please note that it is only similar to spigen armor - the final case will be designed and made by us.
- Case 1 (Black)
- Case 2 (Red)
- Case 3 (Red and silver)
- Case 4 (Clear)
- Case 5 (Pinkish red)
- Case 6 (Spigen armor)
0 voters
