Will cell phone rings work on this case?
For example
Phone Ring Holder Finger Kickstand - FITFORT 360° Rotation Metal Ring Grip for Magnetic Car Mount Compatible with All Smartphone-Rose Gold https://www.amazon.com/dp/B07F37PB44/ref=cm_sw_r_cp_apa_i_MvzvEb07NXD1M
It might put some extra strain on the TPU case in some areas and make it susceptible to tear. I use a magnetic car mount. It needs a metal disc on the phone/case side. Instead of sticking it to the case (like @Frontpage32) what I do is to stick it to the phone body using a transparent tape. And then put the case on.
Hi yes it does cause some strain on the case but I make sure to slide it off vs pull. I sometimes forget to slide it but I am starting to do that with my work phone as well.
