I’ve had the 2e for a few months now, and have noticed that there are certain apps that I never receive notifications for. I’ve tried the following for each app, to no avail:
- Turned notifications and allow notification dot on in Settings → Apps & Notifications
- Disabled battery optimization
- Confirmed notification settings within each app are correctly set
Additionally, I am not using a task killer app. I’ve used all of the impacted apps before on other devices without having problems getting notifications. Wondering if anyone has had similar issues and been able to find a solution.
