[Certified] Android 13.2.1 for Teracube 2e Emerald (SN:2021)
Hi there!
I would like to update teracube 2e emerald’s android 12 to the new 13 version,i’m using /e/os 2.3.6-s and i don’t no how to do it,so some help would be cool : )
thanx in advance and have a nice day!
If you’re currently on /e/os and wanting to be on stock 13 instead, you’ll want to follow the directions to return to the original factory firmware. It’s linked at the end of the original post. After that’s done, go through the 1-7 steps just above it.
A new security upgrade is available! Check for Updates in Updater (Please note it rolls out gradually and might take days before its available to update for everyone) or apply manually from the main post.
Just updated two phones no trouble at all. Looking forward to 14 or 15.
Please confirm whether or not the latest update works with AT&T cellular service.
I agree. I went through a hellish couple weeks trying to troubleshoot having a phone that would make phone calls after an Android version update sent out be Teracube this summer, and eventually had to factory reset, which was incredibly frustrating. If this update doesn’t work for AT&T network, that needs to be warned with the sending of the update, not just on forums or after the fact.
We have internally tested AT&T both Calls, SMS and Data worked fine.
A new update with security updates upto March 5, 2025, is now available! You can either check the main thread for manual installation or wait a week for it to arrive automatically!
Security updated is out of date and will not update on two phones
Got one phone to update fully but not the other one it says it did but security patch is still Feb. not March also it will not install march by it’s self.
Do share the screenshot as to where you are seeing. The vendor patches might be older and that’s expected (Will patch that up in coming SMR). Usually the patch level in Android version matters.
here you go.
Thats Play system updates these are issued by Google directly. Our patch level is already on March 2025.
It down loads the update and installs it then on reboot it takes long time and then doesn’t start and reboots again. If I go to security it say to update it but never works. My other updated and installed the security update
One of my units will do this as well. Just keep patient and it will stick.
After installing the latest update noticed that the autofocus on the camera isn’t working. Related?
Were you experiencing this before as well?
Yours will be the first report of such I am aware of.
Are you using the default Camera app, or a different one?
Have you tried a factory reset yet?
After last week’s OTA patch, I had the same issue on Zirconia, both with the default app and with OpenCamera. I had been about to file a report, but then another patch came out and the camera focus worked again after I installed it.
(Since patches don’t normally come out so close together, I’d assumed you’d gotten deluged with camera-focus complaints and had released the second patch in response to it. Surprised to hear you hadn’t seen any prior reports.)
I’ve have a Teracube 2e Emerald with eOS for about 3 years. Its had eOS Android 12 for over a year now. It feels like the eOS folks are focused on the Fairphones the Xiaomis and other phones. I know you have Android 13 on the Teracube side for a while. Would the upgrade process you have work with eOS in order to switch over to Android 13?
