NOTE : These builds ONLY WORK for the Teracube 2e Emerald (SN: 2021), and not Zirconia (SN:2020). Please read the differences here carefully and flash accordingly.
If you are looking for SN:2020 Teracube 2e (Zirconia), then click here.
We are thrilled to share our 8th stable (13.2.1+438bbe4) (Google) certified Android 13 for Teracube 2e.
What’s New?
- New security patches upto March 05th 2025
Steps to Upgrade:
- Goto Settings > System > Updater (or Teracube Updater)
Note 3 : Before you update, make sure you have at least 6GB of free storage and your battery is at least 50% charged. This will help ensure a smooth update process. - Select the file and continue the update process.
Note: If the Updater closes or crashes, then try again. - Upgrade process will take a while.
- Reboot the phone after the updater says “Update installed”.
Note 4: If you are facing any network related issues then please reset your APNs Settings by going throughSettings -> Network and Internet -> SIMs -> Access Point Names -> Three dots -> Reset to defaults
Do note, after the update, you’ll need to re-enroll your fingerprint and some users have reported that they lose their launcher - icon and widget arrangement. We’d suggest you take a screenshot of your homescreen before performing the update!
If you experience any errors/issues, you can flash the original factory firmware using the automated installer or SP Flash.
