Corrupt Teracube 2e - Android 13 beta 2 (Zirconia)
My Teracube 2e (Zirconia) got corrupted after I let it drain the battery (1%) in standby.
After charging it to 8%, I booted it up and than the error message came after a start cycle (with the logo turning);
Android Recovery
Teracube/Teracube_2e/Teracube_2e
11/RP1A.200720.011/202111011925
user/release-keys
Use volume up/down and power.
Can’t load Android system. Your data may be corrupt.
If you continue to get this message, you may need to perform a
factory data reset and erase all user data stored on this device.
  1. Try Again
  2. Factory data reset
  • Is there a way (program?) I can copy it to a pc or restore the system?
  • Could this be a ‘nasty’ battery problem I discovered with the Android 13 beta2?
Some extra information:
I installed Android 13 beta 2 from the latest 12.1 beta, 2 weeks ago.
In the past week, I did restart it at least once… maybe even a full shutdown.
It tried several restarts and also pluggin out the battery.
I do have a backup… there are some audio files I would like to recover… i’m not panicking whatsoever.
For now, I’m just gonna use my 2nd Teracube…
Also a great start for a fresh installation…
