there is a new update of /e/OS, 1.15-s-20230913330639-stable-emerald for the teracube 2e.
Any issues?
The last update is v1.17 and there is one issue regarding VoWiFi in validation…
The v1.15 wasn’t delivered and isn’t available anymore at the build downloads: zirconia/emerald
thanks
Got the numbers mixed up: that was the current version. Available version is e/OS 1.16 according to the phone. Oops I just hit the refresh and now it is 1.17.
You may have to refresh five times in a row to see an update. That is how they stage/roll-out their updates.
Loaded /e/OS 1.2 on my T2e and it’s running beautifully.
Glad to hear it!
I am on v1.21 myself and VoLTE is back (but now VoWiFi isn’t :P).
I really like how v1.20 includes the microG Google Play licensing check, so downloading and using paid apps from your Google Account should work much better.
Hello I have the zi model of the teracube 2 and looking to install this os, when prompted to see if I have install the drivers for this model I am directed to a web page for the z model drivers but the web fails. Not sure what to do as the other model drivers page there for it. Just tired of the issues with Android 13.
Zirconia should be EasyInstaller supported:
https://doc.e.foundation/easy-installer
If not, you can follow the manual install instructions:
https://doc.e.foundation/devices/zirconia/install
If you are on Windows, Windows update should fetch the needed USB driver.
Thanks will give it a try
