ahoy all,
i am wondering how to get exFAT support enabled for the stock Android 10 or 11 beta on the Teracube 2e? it seems to have been available in Android for quite a few versions though may require OEM support. however i have tested with our 2e on Android 10 and get an “Unsupported SD card” error.
since the 2e supports microSD cards > 32GB and for those cards the default/recommended filesystem is exFAT, i would guess that the 2e could also provide exFAT fs access.
thanks for any help in advance. i also would be happy to test/try out any “experimental” solutions and report back to help get this into the stock OS.
thanks and take care, w
