If you are looking for flip or wallet type cases, they are listed on aliexpress.com (search for Teracube 2e). Quite cheap but I cannot vouch for the fit. I do know it may take a while to reach its destination.
this is not a specific case for the 3e its just a generic fit one they use for a handful of phones that are the same dimensions. there are also now “aftermarket” screen protectors they specify for the 2e for about 3$ for 2 of them in glass from aliexpress
Could someone please give the phone dimensiosn and some other models of phones with the same dimensiona so I can source a protective case that will work for the 2e. Not bothered if I need to make some DIY adjustments for phone jack ports etc…
The closest fit case would be the Huawei Y6/Y6P. The buttons and fingerprint hole are just a fraction off but usable. The hole for the headphone jack is not in the right place though, you’ll need to punch a hole at the top. Hope this helps.
Thanks! Will post a picture of how it looks!
Does anyone have an update on this? I’ve been looking around a bit for a (black) wallet case for mine and was wondering if anyone found a good one (that doesn’t block any ports or camera’s, fingerprint scanner optional, i don’t use that). None of them seem to be using the right phone in their pictures or have any reviews. A few weeks ago i found one somewhere that looked a bit less dodgy (unknown chinese brand and two months to ship, but at least the picture matched), but i can’t find it anymore.
