Google Play System Update stuck
I am updating Google Play System Update manually (didn’t know there were also updates).
I did like, 3 different updates and now I am stuck at a 66MB update.
It installs but after a restart, the update is ‘vanished’, because the 66MB update is still there when I search for updates.
I did the following;
  • Wiped cache from System webview, Play Store, Play Services
  • Went into safe mode and installed it than.
  • Disabled developer options.
  • Deleted system cache via recovery. (I could try Safe mode again and try installing again)
Also; my system boots 2 times with boot logo and moving leafs before entering the system.
That’s also strange behavior
Do you have any ideas what I could try?
Do you know what month update you are stuck on?
Ah yes, April 1st 2023 on the 13.0.1 beta 2 Android version, Zirconia model.
Google Play Store is up to date in app.
I installed Android 11 on another Teracube 2e and did the updates too and they worked flawlessly; on November 1 2023.
My current phone has now magically a 64MB (I think it’s the same update sort of) update that is stuck after reboots. So, yeah, as always patience is key here, I guess. At least I can use Uber on the other phone with Hotspot Internet. Gonna try it tomorrow.
It might just take some time, not all of my Teracube units are on the Nov security patch level yet, despite being current otherwise.
I confirm that too. Zirconia model and the same beta 2 of Android 13. Stuck on April 2023 Google Play system update.
Confirming on Emerald A13B2.
Thanks for the info, all.
