Hi everyone,
fellow European newbie teracuber here!
First of all I would like to thank the team that has been working on the Teracube2e: the idea behind the smartphone is terrific and it seems really well executed. And even when some issues occur, as in my case, I trust the community support.
So, here’s my case: during the last couple of days I’ve been setting up my teracube, my previous smartphones were all mainstream consumer ones, strictly android. I’m not an expert at all, but I’m willing to learn.
While setting up my teracube I decided, for privacy concerns, to install a new keyboard, open-source and not linked to google, called OpenBoard [ Version 1.4.2, apk downloaded from f-droid].
Everything worked absolutely fine, I disabled Gboard, the default one.
I then had to turn the teracube off, remove the battery (I needed to remove the sd-card), and turn it on again and, as the smartphone turned on and asked me to enter my password (no finger print, no pin, no gesture, no facial rec) the keyboard just didn’t show up, resulting in me being locked out of my phone.
I rebooted it three or four times, even with battery removal in between, but it’s always the same, I get no keyboard trough which entering my password.
What can I do? Would getting it to safe mode be helpful? And how can I prevent such failures from happening in the future? Should I use a keyboard of choice and not disable the default one?
Thanks in advance to anyone who will be so kind to try and help me get back in my beloved teracube.
Best regards,
b4da
