I figured the smartest option would be to ask here. I’m willing to buy additional components (SD cards or whatever) but wouldn’t know what steps to take or the exact hardware, especially on a device that’s supposed to be easier to customize than your typical Android device.
RAM is soldered on-board. You’re not upgrading it without a reflow station and some serious skills. Same goes for the on-board storage, CPU/GPU, etc. The board is not modularized/componentized for upgrading.
About all you can do is swap the battery and upgrade expandable storage with a microSDXC card.
