To migrate your contacts, calendar, mail, and notes from your iOS (iPhone, iPod Touch, or iPad) to your Teracube phone, you first need to have a Google account set up to do this.
If you have an EXISTING Google account on your iOS device, make sure that it’s set to sync your data:
- Go to Settings > Passwords & Accounts on your iOS device.
- Select your Google account.
- Make sure that Mail, Contact, Calendars, and (optionally) Notes are enabled to sync your data with your Google Account. If not, enable them and it should take several minutes to sync the data.
If you DO NOT have a Google account on your iOS device:
- Tap on Add Account.
- Select Google
- Tap on Creat account to create your Google account.
- Follow the instructions to set it up.
- After setting up your Google account, make sure that Mail, Contacts, Calendars, and (optionally) Notes are enabled. Syncing the data for the first time may take several minutes.
Syncing your photos from the iPhone to the Teracube One:
- You must have an existing Google account on your IOS device
- Install Google Photos from the App Sttore.
- Select the Google account (or accounts) that you want to sync with your iPhone
- You should then be able to sync the photos to your Google account; the initial sync make take a while depending on how many photos are on your iOS device.
Now you can setup your new Teracube One with your Google account. The data will sync to your phone.
To sync the photos to your Teracube one:
- Install Google Photos from the Play Store
- The photos will sync to your device
