Increase keyboard speed?
Is there a setting where I can adjust the “speed” of the keyboard? As in, it doesn’t keep up with my thumb typing, and I’m not sure if I’m looking in the right place in settings to change that, if it can be changed. For example, when I’m typing quickly, when I type “things”, I get “tig”, or if I type “something”, I get “smtig”.
And yes, I have removed the protective sticker over the screen!
Could you try the suggestion(s) on this page - https://android.gadgethacks.com/how-to/quick-tip-speed-up-gboard-performance-android-by-disabling-these-two-settings-0175748/?
Other thing to try is an alternative 3rd party keyboard like Swiftkey (disclaimer: at your own risk)
Thank you, I will try those steps.
Overall, I am very happy with my new Teracube, I feel I should mention!
Somewhat following the article, I disabled:
  • block offensive words
  • show emoji suggestions
  • show sticker suggestions
  • suggest contacts
and I turned off haptic touch.
This seems to be working pretty well! Thanks for your help.
