| Feature | Teracube 2s |
| Operating System | Android 14.0 with Google Play Store |
| Processor | MediaTek Helio G36 Octa-core processor 2.35Ghz |
| Memory | 4GB RAM with 64GB storage |
| Screen | 6.1” HD+ IPS Display (720X1560) |
| Rear Camera | 20MP+8MP (wide angle) |
| Front Camera | 8MP |
| Battery | 4000mAh replaceable lithium-ion polymer battery |
| Security | PIN, pattern, fingerprint, face unlock |
| Connectivity | WiFi A/B/G/N/AC, BT 5.0, NFC (Supports Google Pay) |
| Ports | Headphone Jack, USB-C port, Dedicated Dual SIM with separate Micro SD slot |
| Sensors | Accelerometer, G-sensor, Magnetometer, Gyroscope, Ambient light sensor, Pedometer (step counter), Proximity sensor, Orientation sensor, Linear Acceleration sensor, Rotation Vector sensor, Game Rotation Vector sensor, Significant Motion sensor, Step Detector, GeoMag Rotation Vector sensor, FM radio |
| GPS | GPS, Glonass, Beidou, Galileo |
| Size | 155.2mm x 73.3mm x 10.1mm |
| Weight | 190g |
| Color | Black |
| LTE (4G) | 1 / 2 / 3 / 4 / 5 / 7 / 12 / 17 / 20 / 66 |
| GSM | 850 / 900 / 1800 / 1900 |
| 3G | B1 / B2 / B4 / B5 / B8 |
