My wife and I got “Suckered” into buying a Freedom Phone We do NOT like it. We can’t return it without losing 50% so, it’s collecting dust. I LOVE my Teracube 2E and the e/OS products. The “Freedom Phone” is basically a Umidigi A9 Pro. I assume I can dump their ClearOS and flash it with the e/OS. But I don’t know how. Can you point me to a site that will guide me through the process?
Unfortunately, it looks like none of the major alternate OS flavors are generating options for any of the Umidigi phones, but if it’s just a rebranded Umidigi A9 Pro then you might be able to update it from ClearOS 10 to stock Umidigi Android, and then possibly shift it from there to a newer AOSP version using directions similar to the following:
[How to] flash GSI on Umidigi A7 Pro - Functional Guide | XDA Forums
Of course the standard disclaimer that is for a different Umidigi model, rebranded Umidigi does not mean identical, etc, etc. Also a note that Umidigi reuses the same model numbers over and over and over again and your A9 Pro 4GB could be the A9 Pro 2021 New ( UMIDIGI COMMUNITY-A9 Pro 2021 New - Powered by Discuz!) or the A9 Pro 2021 ( UMIDIGI COMMUNITY-A9 Pro 2021 - Powered by Discuz!) or the A9 Pro 2020 ( UMIDIGI COMMUNITY-2020 models-A9 Pro 2020 64GB - Powered by Discuz!) or even something different from all of these.
Best of luck.
