If you been having sim issues with metro by t-mobile like I had for the past week. Here’s a fix. Make metro your main by putting the sim card in the first slot. Metro by t-mobile is very finicky in regards to how you activate it. If you would prefer to have the sim in the second tray when you call metro give them the second imei number. Otherwise, it will not work. I hope this helps.
