I got my Teracube replacement and all of a sudden I’m getting the following error.
Any ideas?!
Did you have wifi calling enabled on your previous unit?
Two options:
- If you need wifi calling enabled, then you might have to call your carrier and check on the settings.
- If you were not using wifi calling before or don’t need it, then you can disable it under Settings > Network and internet > Mobile network > Advanced > Wi-Fi calling
I did and I was on PixelExperience.
For the ones who might face the same issue, what I ended up doing, is entering my address under E911 Address under profile settings within the carrier website.
