Just received my new Teracube case from Amazon.ca. Only took two days from order to pickup. So far I think it is a safe case. Bit of a raise in the front to help cracking the screen. Much better than the case that came with the phone. I know first hand about that. I dropped my phone and it landed in the right spot to destroy my screen. Mind you I did not have the glass protector installed. So to all of you out there. Regardless of your new case which you should buy first chance, put on the glass screen protector. My only complaint about the new case is that the camera on the back should have had the raised edge. Just a thought. Thank you Teracube.
