If you are seeing an orange border on your screen, then it is because magnification got enabled as part of Accessibility. If you need Accessibility and magnification, then this is as expected. If not, then read on on how to fix.
To fix : Goto Settings > Accessibility. Disable Magnification settings and Accessibility menu. (Accessibility menu is what you see at the bottom-right of my screenshot above)
