I can’t get Pandora to work on my 2 e. It keeps saying my Pandora session has timed out, or error code 3005, or “waiting for connection, try again?”
Anyone else having this trouble? Any ideas?
I have uninstalled it and reinstalled it at least twice with no success.
Yeah - this is a known issue most likely on the Pandora side. Read more here -
Same here. I have some back up APK of older Pandora versions. I’m going to try them later this week.
I downloaded the pandora app from the play store earlier this morning and had the same problem others are reporting.
But it works fine if you play it from a browser. I’m listening to it through Brave with Desktop Site selected. Not a perfect answer to the question, but a decent workaround.
Version 2101.1 seems to work fine now.
Yupp - just now tested it to be working. Seems like they fixed it on their end.
