Phone icon issue
the phone icon is pressed to answer a call, goes immediately to a solid white screen, you hear one ring, then it closes ending the call and returns to home screen.
Sorry to hear that.
What version of Android and what carrier?
the version of android is 11 and the carrier is ATT
Can you please use the System Updater app to check for and install any pending updates from TeraCube?
We have launched Android 13 as Stable, so it should be waiting for your device once you check.
there is no update to android 11 says the phone. says phone is up to date and offers no update
Can you confirm the first four of the serial? It will tell us if you have an Emerald (2021x) or Zirconia (2020x) device, so I can link you the manual update files.
build # Teracube_2e_A11_05
serial # 202111T2E001611
Thanks for confirming.
Please follow the instructions here:
Take a backup of any important files before the upgrade, and ensure your Google Backup has completed recently if you make use of it.
