Phones don't work
Good evening… Whats the odds of getting 2 teracube phones that do not work.
phone #1 will not boot. Goes to factory set up screen.
phone #2 i managed to set everything up, added it to my carrier (consumer cellular) and it wont stay connected to the network. Connects at LTE for 3 minutes, then completely disconnects and says its only available for emergency calls at 6 minutes. Would appreciate some assistance
Hi James - apologies for your experience. That is definitely bizarre.
Phone #1 : Could you take a picture of the screen.
Phone #2 : Can you call Consumer cellular support and check what could be going on? Consumer cellular works on T-Mobile and AT&T and hence should be compatible with Teracube.
If we can somehow get your Phone #1 to work, then we can test the SIM in there.
