PLEASE help me identify this chirp my Teracube is making
I can’t find anything on this sound my phone is making. It’s 3 sharp chirps. I was able to get a recording of it. That was a nightmare to do
  • Nothing shows up in notification history
  • I turned off any emergency/AMBER alerts
  • I cleared the calendar and alarm apps (Because that sound closely resembles it)
I don’t see this sound in my list of sounds to choose from and I combed through the entire gitlab for that asset and had no luck. The worst thing is how inconsistently it plays with nothing on my phone showing signs of it’s existence.
  • It tends to happen everyday at 10:13 am but not always, just mostly
  • It seems to happen a lot around a minute after a reboot.
  • It can happen without warning at anytime, sometimes twice in a short period.
    I’m running the latest version of /e/OS (v2.5)
I hope it’s something easy for someone more familiar with Android than I am. I’m not sure what else to troubleshoot besides MAYBE combing catlogs but I had to luck trying that before. Thank you in advance. It’s driving me crazy
I discovered after resetting notification preferences it was the libre app. Sorry about that
Great detective work.
Which app in specific was it?
Sorry for the late reply. It was https://play.google.com/store/apps/details?id=com.freestylelibre2.app.us
I had no idea apps could still make noises even when the notification is turned off so it led me to believe it was on the OS level at first.
