Reinstall deleted apps
Accidentally deleted Digital well being and Spin from child’s phone and can’t reload them through Google Play store. How can we reinstall them?
You can try pushing it to the device by using the Google Play Store from a desktop web-browser:
Hi @RHC - Ideally, these are system apps and should not have gotten deleted. It is possible that they got hidden.
How to unhide apps
  1. Open Settings > Apps & notifications
  2. Search for your app
  3. See if it is disabled. If yes, enable it again.
If you still can not restore them, then will have to do a factory reset. Settings > System > Reset options > Factory reset.
Feel free to schedule a call to discuss this issue.
Hi @RHC - there is a chance that the apps got hidden. You can unhide them with these steps:
