Struggled with my Lucky (Part of Bellsim as the holder seemed a bit off with the larger card. I tried getting it in but the holder came out without the sim which is now stuck inside. How do I open the phone to get my SIM out?
Oops - sorry to hear that. Instead of opening the phone, lets first try if there is a way to pry/pop the sim out. Could you try some of the tricks mentioned on this ifixit forum. Let us know if that helps.
