SIM Selection lost in Android 11
I updated my phone to Android 11 successfully. Now I’m missing the to activate/deactivate each SIM. This function ist gone settings/Connections. Instead there is a simple sentence at far bottom, to unplugg a SIM to deactive it. Is this a bad joke?
I loved it to simply switch my business SIM off, when I go on vacation e.g.
Got anyone a solution? May I get Android 10 Back?
MariX
Hi @MariX - yes this change came from AOSP (base Android). You can read more in the Reddit discussion below (its about Lineage but applies to AOSP as well). We will be discussing with the Dev team if we can bring the feature back somehow.
In the meantime, you could go back to Android 10 if need be.
