Soft restarts, 1-2 times per day
I’ve noticed somewhat-frequent ‘soft’ restarts. Typically it’s when I haven’t used the phone for awhile. I’ll pick up the phone, try to unlock with fingerprint, and it tells me something like “Cannot use the fingerprint login after restart”. Once I log in, all apps are closed.
It happens 1-2 times per day.
I didn’t see this listed as a symptom in the runaway thread problem currently being addressed, but maybe it’s related.
Were you able to install the software update? It should most likely fix this issue.
A post was merged into an existing topic: Software update available
Thanks - let me know if any of your colleagues want to join the fun :slight_smile:. Just FYI - moving your feedback to the update thread.
This problem was solved by the recent software update.
