I see Sound Recorder installed on 2e… but not sure how to get it to work?
It is a voice notes/recording app. You can press the red button to start recording. The 3 lines show all the previously saved recordings.
That’s what I thought… but I touch the red button & nothing happens?
Just tried my wifes’ 2e… the recorder works on hers but not mine… I probably need to permit something… but don’t know what?
Have you given the app access to your microphone and storage? Check the permissions for it.
How do I do that?
OK … got it… I had enabled the microphone but not the storage… it is working now. THANKS for the help!!
Now I can’t seem to name or rename them?
You are right - renaming the recording is not supported as of now.
Ah too bad😒
Can’t it be done in Google Files? More options there generally I believe.
