After the Teracube_S1_06 software update, I’m still experiencing poor battery life. I’ve done a factory reset without installing any additional apps and receive the same results. I then added a single app, SystemPanel2, in an attempt to troubleshoot. I found that the CPU Clock Frequency spikes and remains at a high level, until I reboot the phone. The battery drain coincides with the high CPU Clock Frequency. I’m unable to see which process is causing the problem as it’s listed as “unaccounted”.
The screenshots show that shortly after I went to bed, the CPU Clock Frequency spikes. It wasn’t until I woke up, realized it, then rebooted the phone to return it to a normal state.
