Teracube 2e case 3D file
Here is the .stl file from solidworks import of the .stp file, it should be just the same.
I’ve also completed a Solidworks modification of this file that removes the corner “bumpers” as I described. It’s more of a kludge than I could have accomplished with the original design file, but hopefully it will be easier on my pockets. I’ve ordered one, but don’t want to post the file until I know it prints something useable.
Thanks, I think I’ll wait for the new version so if it works I’ll just use that one, thanks for the stl file nonetheless
This is what the case without bumpers should look like when printed. I was mostly able to use the contours of the main case to “cut” the bumpers off, but was left with some corners that I had to “plane” off (the flat faces). I also increased the size by 1% because the current Craftcloud case was very tight.
I got my case without the bumpers yesterday, and it seems fine so far. I had increased the size by 1% and I can now get the case on and off without taking the back off of the phone. The .stl file is here. I used Craftcloud to print in black TPU with 20% infill this time. The “planed off” corners are evident, but not as obvious as I’d feared. With the “grain” of the printing, it looks better, I think.
Awesome, I’m gonna get mine printed :slight_smile:
Hi there, my 2 original cases have been thrown in the trash… and now I have my own green 3D-printed case!
I am already at version 3; I edited the Teracube STL in Tinkercad.
If anyone is interested, I can post it here. (without my logo of course)
Version 4 needed because, some things don’t feel right yet.
Gonna try to post a picture with the phone in the case, then.
  • I added extra borders, because the filament is pretty flexible.
  • Also, the right top border acts as a light blocker for the battery light.
  • I made the charging hole a bit bigger for my charger.
  • I changed the power/volume buttons for better tactile control (as in, feeling what button is which)
  • Straight walls for better printing (now too straight, there is room to let the wall slant a bit)
  • I’m going to tidy up the space between te original wall and new wall, it seems to give some grip when I put the phone against a wall (not fully closing it, else it seems too bland)
  • I deleted some relief that made 3D-printing it more difficult, I added some extra height in the top inner walls. (I try to cover as much bezel as possible)
  • I deleted the 3.5mm jack, but can always be added with a soldering iron. #Easy3D
  • I added 1mm to the bottom (I added my own logo, 0.8mm thick, as a line so 3D printing layers on top would not have interference).
Edit; I just popped my other T2e in the case and took a picture :sweat_smile:.
Here I am just sharing my tinkercad of my case. Was thinking about removing my logo, but since it it isn’t of purpose anymore, it’s there as an example. Happy tinkering!
