[Teracube 2e] Instructions to Install Factory Software and to Reset
It does not, no.
The SPFlash utility is meant for flashing the OEM image and partitions and communicating with the phone in a special lower-level mode that makes it (almost entirely) unbrickable and able to be recovered. Secure data erasure is a non-goal of this tool, from what I can tell from how it is laid out.
In terms of data recovery, a consistent write of 1 or 0 is easier to recover than (semi)random data written over it, so reflashing the user partition and maybe dumping a bunch of random-filled files on it between reflashes will be a much better secure-erase process. You can generate them on Linux with something like this: head -c 1G </dev/urandom >myfile
So I just received a warranty replacement device. Despite being told that the device would ship with Android 13, which should resolve security concerns from Android 11, the device in fact came with Android 11.
Unfortunately, I only discovered this after I logged into my Google Account on the phone.
When I went to Settings > System > Update, it showed me the following update was available:
Teracube 13.1.1+a21467d.emerald.user
Question 1: Is there a difference between installing v13 through the settings menu versus the process described in the original post in this thread? Specifically, I’m thinking about differences in device security, but curious to know others as well.
Question 2: Is it a problem that I logged into my Google account before updating to v13. It has been stated in several other threads how v11 had several known exploits that were blamed for the previously reported hacks where SMS 2FA codes were being forwarded by the phone.
Note: I never did and still have not put a SIM card in the replacement phone.
  1. No, the are the same image, just applied differently. The manual flash is more of a failsafe/full recovery, whereas the upgrade from within Android doesn’t reimage everything as it isn’t needed on a functional device.
  2. I don’t think that this is a likely risk factor, especially if your Google account is secured with 2FA and other best-practices. I’ve tested every build from TeraCube across Zirconia/Emerald/Thrive/Ruby with the same Google account, starting with Android 9 images, and I have not noticed anything suspicious at all in the logs.
These images will be updated with Android 13 stable builds.
Hi,
we are in the process of refurbishing a few Teracube 2e (2021) that we have. Would it be possible for you to make the Android 16 update packages available for Linux (using SP Flash) ?
It seems these images should exist as said in this thread :
I pinged the team and let them know.
Edit:
The SPFlash images for both Zirconia and Emerald are now posted in their Update threads:
Hello is there a method like this for the Thrive model in case a user needs to re-install the factory software
There is a internal method and tooling to do so, and I have done it for testing/validation, but I am not sure if this can be public.
Let me ping the team and get an answer on what the best process is for this case.
I suspect it will be to perform a Factory Reset from within Android or from the bootloader/recovery.
That would be very helpful
At this time, the only supported method for Thrive is via Android or Bootloader/recovery reset.
Is there anything different when performing on 2S?
The Android 16 link in the first post will handle Sapphire (2s) devices as well as 2e devices, so not when using this method.
