[Teracube 2e] Instructions to Install Factory Software and to Reset
Caution: This will factory reset your phone and wipe data. Please backup before proceeding
The following steps will allow users to install factory software on Teracube 2e. Works for both batches - Zirconia (2020) and Emerald (2021).
This is an easier and more automated process as compared to the manual SP Flash process. It will do the following:
  • Install factory software
  • Reset the phone
  • Remove any old pins and security
Requirements
  1. Windows 10/11 computer.
  2. Teracube 2e phone (will not work on other phones).
Steps:
Install Drivers (if you have never run SP Flash before)
  1. Download and install these drivers (link).
  2. Reboot your computer
Flashing instructions
  1. Download one of the below packages on your Windows computer.
  1. Unzip the package
  2. Double click the ā€œInstallT2eFW.batā€ file to run it.
Note: Windows might prevent you from running the bat file. Click ā€œMore infoā€ and then click ā€œRun anywayā€.
  1. Power off the phone
  2. Connect the phone when the software asks you to.
Note: If your phone is boot-looping (not staying powered off), then plug the cable precisely when the screen goes off.
  1. Do not unplug. Wait few minutes till process completes.
  2. Once finished, power on the phone.
Note: Make sure the phone is powered off while plugging in at step 7
Please post your questions/comments below.
[ Troubleshooting ] Factory-Reset with No Touchscreen
[ Advanced ] Unlock the Bootloader
[Final Beta] Android 12.1 for Teracube 2e (both batches)
[Advanced] Installing factory Android image w/ SP Flash
Guide to install iode OS on Teracube 2e (SN:2021) using a Mac and terminal
Instructions and 'boot.img' for installing Magisk onto SN2021 emerald?
[ Troubleshooting ] Recovery Mode
[Certified] Android 14.1.0 for Teracube 2e 2nd Batch Emerald (SN: 2021)
Reimaging Terracube 2E
Teracube updater is missing
[Certified] Android 13.1.1 for Teracube 2e Zirconia (SN:2020)
[Certified] Android 14.1.0 for Teracube 2e 1st Batch Zirconia (SN: 2020)
Android 15.0.1 for Teracube 2e 2nd Batch Emerald (SN: 2021)
Factory OS installer now supports Android 13
[Certified] Android 13.1.1 for Teracube 2e Emerald (SN:2021)
Android 15.0.1 for Teracube 2e 1st Batch Zirconia (SN: 2020)
Need Help: 2e Black Screen and Unresponsive
Android 16.3.1 for Teracube 2e 1st Batch Zirconia (SN: 2020)
Android 16.2.1 for Teracube 2s Batch Sapphire (SN:2025)
Android 16.3.1 for Teracube 2e 2nd Batch Emerald (SN: 2021)
Battery drain after recent update
Nuked cube
Bypassing Android's FRP on a Replacement Phone
[Beta] Android 13 for Teracube 2e
Wich FM radio App you use?
Teracube 2e APN settings: MMS šŸ‡ØšŸ‡¦
Updating to Android 12
[Beta 2] Android 13 for Teracube 2e
How to contact Teracube support
Slow Restarts after Updating to Android 13 (and a few other issues)
Help with eliminating malware surviving a factory reset
My Teracube 2e, currently on Build number Teracube_2e_16, has been crashing (i.e., turning itself off and NOT restarting) 2-3 times per week. Sometimes it’s more than once the same day.
Would you advise resetting with these instructions?
Thanks…
Hi @peterforint - sorry for the late reply. You can do one of the following:
  1. Try a soft reset followed by a full reset.
  2. Upgrade to 11.0.4.
  3. Use the above instructions to re-install factory firmware.
Hello @Sharad ,
The guide seems pretty straightforward (have not tried it yet). I see that there is no distinction between the ā€œfirst batchā€ and the ā€œsecond batchā€ (emerald) T2e releases. So this procedure works for both releases?
UB
Somehow missed out on replying here. Yes - the above process works for both 2020 and 2021 Teracube 2e units.
when I plug the phone it doesnt happen anyting and the operation doesn’t advance, what can i do?
Please check your USB cable and port work properly with other devices, and try again.
The phone must be off for SPFlash, and this script, to function.
fail
Please don’t use a pay software for this. It’s required to buy this software.
Please an instruction for Linux (Ubuntu 22.x LTS) or a OS that can used without installation.
The SPFlash method remains supported for Windows, MacOS, and Linux.
This method is meant specifically to be an easy method for the largest userbase.
I’m trying to follow the instructions from this thread’s OP. I found that the link to the USB_VCOM drivers (https://downloads.myteracube.com/Drivers/MediaTek_Preloader_USB_VCOM_Drivers_Setup_Signed.zip) is currently broken. Would it be possible to update the link please?
Thanks!
Sorry for the trouble.
I’ve let the team know and the links/files should be fixed presently.
Thanks for the reply @Saijin_Naib! Will this thread be updated when the link is fixed? Just tried it again and I see that the link is still broken. I realize it hasn’t been very long but wanted to make sure I’m looking for the fix in the right place.
This thread will most likely be updated, and if/when I hear back from the team that the resource has been placed somewhere, I will update you if someone else does not first.
Awesome, thanks @Saijin_Naib
Drivers link fixed in OP - thanks for letting us know.
When I got to step 5 above, ā€˜Double click the ā€œInstallT2eFW.batā€ file to run it’, and followed the Note about Windows, it pulled up a command prompt asking if I wanted to run the Flash. I typed ā€˜Y’ as prompted, and nothing happened. I had to restart my PC again after the second unzip, to activate the files. Then I could do step 5 and forward.
I’m trying to follow the instructions for using SP Flash to install factory software on my 2e on MacOS, but am running into problems with SP Flash not being supported. I’m also having trouble getting tools like Wine to try and run the Windows version. Are there instructions or any guidance on how SP Flash can be used to install the factory software using MacOS? I’m fine to follow the manual process, but I’m stuck at being unable to run flash_tool.exe.
Unfortunately, SPFlash is not supported on MacOS, and as you noted, Wine/DarWine will not run it properly.
You will need access to a Windows or Linux machine for the flash using SPFlash.
The procedure worked, however I had to reboot PC after point 4 to make it work
Does this procedure actually write zeroes across the entire internal memory of the phone, thus permanently wiping any user data and making it 100% unrecoverable?
If not, is there another recommended way of doing this before disposing of a Teracube or sending it back for repair?
